Raw water system cleaner
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Has thanked: 5 times
Been thanked: 7 times
Post by Youghster »
I'm thinking to clean the heat exchangers on my 5.7 Crusaders. I saw a utube video that featured "Barnacle Buster" and, if it works, I'm game to give it a try. Do any of you skippers have experience with this or a similar kind of suck it up and soak it product ?
Fishsail
Vessel Info: 1991, 420 aft cabin
Has thanked: 17 times
Re: Raw water system cleaner
Post by Fishsail »
I tee off the main intake strainer with another valve as a flush point and an emergency bilge pump. I run a diluted solution of Mariatic acid and fresh water, (about 20 % acid) thru the cooling system , let it sit for 15 min. And run engines normal to flush out the acid. All kinds of junk comes out. I do this about once a year. Eng. temp’s usually drop 10 deg. Caution! Don’t use too much acid or let it sit too long. It can eat up the solder on the cooling bundles.
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Post by Youghster »
Thanks for the tip. We used muriatic acid in cooling systems of continuous miners underground so that was my first thought. Then I saw a product designed for the job and wondered ? 80 / 20 for 15 minutes Thanks again
