I recently aquired a 2001 396 Carver Aft Cabin.
I am not able to locate the aft bildge pump or the forward bildge pump.
The forward bildge is not under any of the access panels in the forward state room.
There is no access panel on the galley floor. I imagine its in the engine room behind the generator but I have yet to find it.
Regarding the aft bildge pump. I pulled up the carpet in the aft state room and removed all the access panels and no bildge pump. I did find the shower sump pump.
Could it be that Carver would hide the aft bildge pump under the shower sump? If so, you would have to remove all the drain hoses from the shower sump and the tub just to check the if the bilge pump functions. Would Carver actually do that or did the previous owner change things? I am the 3rd owner.
My marina neighbor has the same boat but a 2003. The forward bildge pump is under an access plate on the galley floor and the rear bildge pump is easily accessable under an access cover in the aft state room.
When I had the boat surveyed the surveyor noted the lack of easy access to to pumps an "area of concern and needs to be addressed".
Any comments are greatly appreciated.
2001 396 aft Cabin bildge pumps location?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 2001 396 aft Cabin bildge pumps location?
Why not touch base with your surveyor and ask?
And, just a suggestion, but going forward, anytime you have a boat surveyed, shadow your surveyor and have a running conversation. Had you done this, the bilge pump topic would have been discussed as to how hard they were to be found and how difficult it would be to service them.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
The answer to the aft bilge pump location was that the aft shower, sink, A/C condensate pump, and the bridge sink drain all lead to a sump box that is mounted under a carpeted access cover which covers the rear sump pump. I never imagined you would have to remove all the drain hoses and sump box to gain access to the bilge pump to service the pump. I finally got in there and had to replace the float switch.
The froward bilge pump was located under a access plate under the galley floor. The trouble is I had to rip up the floor laminate to find the bilge pump cover plate. That float switch had to be replaced as well.
