3867 location of main circuit breaker
Smooth Dog
Vessel Info: 1988 Carver Santego
Post by Smooth Dog »
Hey
Trying to locate circuit breaker for the interior not AC circuit. Just checked boat to get summarized and the AC circuit is working but the one for fridge, lights etc. is off. Was starting to track down, but don’t know where it is?
Been thanked: 285 times
Re: 3867 location of main circuit breaker
Post by buster53 »
I assume you have 2 shore power connections. Assuming you do, you should have 2 main circuit breakers on your electric panel for 120v power and a separate breaker for your 12v power
Make sure all are turned on.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Post by ColRon »
I have tried to attach a photo below. Working from right to left, you have your 120v ac for air condition with rotary shore power/gen transfer switch with you main breaker. Moving left, you have you 120v ac shore power/gen transfer switch with you main circuit break switch for you cabin power, the far left side is your 12v circuit breaker switches.
Ron
“Escape Plan”
Murray, KY
:usa:
Smooth Dog
I know this sounds dumb, but on the salon panel, both ac on the right and the rest stuff on the left, I just don’t see a main breaker switch
Thanks guys. Going down tomorrow to use the advice. Gus I am looking for a reset button like ground fault.
Post by buster53 »
What are those indicator lights for at the very top of the panel? Pretty sure there is no reset button on the 120v side.
ColRon
“Escape Plan”
Post by ColRon »
buster53 wrote:QR_BBPOST What are those indicator lights for at the very top of the panel? Pretty sure there is no reset button on the 120v side.
On the left hand side either side of the 3 volt and amp meters are 12 VDC circuit breaker lights. On the right hand side below the each of the set Of two (volt/amp) meter groups is the 120 VAC circuit break along beside the red/green polarity lights. Then below that is the Shore power/Off/generator rotary switch. You are correct there is no reset button on the breaker panel.
Ron
“Escape Plan”
Murray, KY
:usa:
ColRon
“Escape Plan”
Post by ColRon »
Smooth Dog wrote:QR_BBPOST I know this sounds dumb, but on the salon panel, both ac on the right and the rest stuff on the left, I just don’t see a main breaker switch
Smooth Dog, on the ac circuit breaker panel you should have two polarization indicator (rectangular red/green) lights. One for air conditioning side and one for salon. To the left of those indicators is the main circuit breaker with a round indicator light. Below those you should have a rotary shore/Off/generator selector switch.
Ron
“Escape Plan”
Murray, KY
:usa:
