carver 350 aft cabin shore power
ataylor233
Has thanked: 83 times
Been thanked: 7 times
Post by ataylor233 »
I have 2 30 amp connections on the back. in the middle is a 2 button breaker id like to replace that breaker and both outlets ... does anyone know a part number or anything … Marinco is on the cover ..
Re: carver 350 aft cabin shore power
Should be able to find the inlets anywhere, just Marinco 30A 125V. You can buy just the guts/insert if the housing is still in good shape. Pull the breaker housing out and check the brand, model, and spec of the breakers and go from there. You'll be able to find replacements.
