New member
- Carver37c
- Vessel Info: 2015 carver37c
New member
I just purchased a 37c. I am looking for any information people have about them. It seems to be a nice Boat but I am sure there are things that will need fixed.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: New member
Welcome Aboard. Good luck with your Carver.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: New member
Congratulations and welcome aboard!
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: New member
Welcome aboard!
- Carver37c
Re: New member
Survey just found a couple small issues with the upholstery and nicks in gel coat. One thing I notice is the a/c unit is not discharging water out the side. I can hear the pump running and the sea cock is open and strainer is clean.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New member
Carver37c wrote:Survey just found a couple small issues with the upholstery and nicks in gel coat. One thing I notice is the a/c unit is not discharging water out the side. I can hear the pump running and the sea cock is open and strainer is clean.
Yes, your pump could be the problem and needs replacing, but try priming the system first. Could easily have an air lock. When you open the strainer, is it full of water? Assuming it is below the water line, water should be overflowing if the seacock is open.
Did your surveyor not make a note of that?
