Slow to drain sink and shower.
trwestman
Vessel Info: 2002 Carver 506
Configured as a Soft-Top Bridge with Glass Aft-Deck
Cummins 450C (480hp) ~725 hours
Has thanked: 16 times
Been thanked: 7 times
Post by trwestman »
(New owner)Carver 506 Aft Cabin sink is draining slow. I have removed the drain to inspect for hair buildup and found none. In my land home I would next remove the P trap and clean it. I found the grey water tank along side the steering linkage. What should I be checking and cleaning to correct this. FYI. Aft Shower drains perfectly.
V-Berth shower drains slowly. Not sure how to address this. Can anyone point me in the right direction?
Tom
2002 506
Rocketman
Been thanked: 24 times
Re: Slow to drain sink and shower.
Post by Rocketman »
Check the hose line routing to make sure you have a good downward routing.
I had one of the showers not draining good and found the hose had a droop in it in the routing that prevented good flow.
I rerouted the hose to create a good drop angle and no more issues.
Been thanked: 285 times
Post by buster53 »
Rocket man has a good suggestion. If that isn’t the problem, I’d pour a cup of a good cleaner (Fantastic, Simple Green, etc) into the drain, wait a while and then hit the drain with a water hose to flush it out. Try simple solutions first.
plittle2005
Been thanked: 37 times
Post by plittle2005 »
From Home Depot, get a length of 1/4" OD stiff nylon tubing. Push down drain hose. This will clear out the schmuck quickly.
