Hi group, I need to remove my port side prop shaft strut. There is access to the starboard side inside aft closet. There appears to be a hatch beside the aft bed under the step ? Is there an easy way to get to the hatch without having to cut the carpet ?
Thanks in advance
Carver 444 access to port strut bolts
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
Re: Carver 444 access to port strut bolts
Which strut, big or small? There’s two on each side. You may be able to access big one from inside lazarete with an extension. If it’s a full removal carpet has to come up but can just be pulled back. Those little night stands come right out and only held by a couple of screws.
