Stringer construction on Carver 325 1997
- buddyrm
- Vessel Info: Carver 325 1997
- Been thanked: 5 times
Hi all, does anyone know what the stringer core material Carver used on model 325 1997 year. I would greatly appreciate it.
- Been thanked: 654 times
Re: Stringer construction on Carver 325 1997
They will be in a grid and will be fiberglass no wood
Welcome to the forum.....
What area are the stringers you asking about....tophat style are quite wide and hollow, some later models had engine bed stringers that were cored with composite type material ( not wood ), those are much thinner, the difference is obvious. Can't say for sure what your model/year has though. Hopefully someone with a 325 around your model year will chime in....
- buddyrm
Are you sure there is no wood? I spoke with different people and everyone thinks there is wood.
- buddyrm
Engine mounts on the center and outer stringers. I wanted to know if they still used wood in 1997. Some say yea and some say no. Hate to drill into them to find out.bud37 wrote:QR_BBPOSTWelcome to the forum.....
How wide are your stringers? Do they have round access plates on the side?
- buddyrm
From the top about 2 inches and high about 6 inches but I would have to do a measurement. I am not at the boat presently.Viper wrote:How wide are your stringers? Do they have round access plates on the side?
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Almost sure they are similar to my 95. They are cored with marine plywood, soaked in resin. A friend of mine tried to replace that core at one point. Cut off the top 2" of fiberglass. Tried to dig out the core, but could not get any out because it was like scraping concrete. That was on an 89. I talked directly to Carver, as my stringers were providing a high reading on an infrared meter. Carver said the meter is probably reading the wood part of the core, but the resin will mitigate that reading. Your bilge is painted grey, which will show cracks in the paint if there is any flex to the stringers. Clean at base of stringer, inspect for cracks in paint. If there are no cracks, that translates to no flex. Good luck.
er
Ya I'd say if they are only 2" wide that they are cored. The Top Hat hollow stringers are much wider than that. Mine are about 8" wide in some spots and about 4-5" in others.
- buddyrm
Cooler wrote:QR_BBPOST Almost sure they are similar to my 95. They are cored with marine plywood, soaked in resin. A friend of mine tried to replace that core at one point. Cut off the top 2" of fiberglass. Tried to dig out the core, but could not get any out because it was like scraping concrete. That was on an 89. I talked directly to Carver, as my stringers were providing a high reading on an infrared meter. Carver said the meter is probably reading the wood part of the core, but the resin will mitigate that reading. Your bilge is painted grey, which will show cracks in the paint if there is any flex to the stringers. Clean at base of stringer, inspect for cracks in paint. If there are no cracks, that translates to no flex. Good luck.er
Thanks for the update, good to know.
