Carver 2807 Gauges Upgrade
wanderer
Vessel Info: 1983 Carver 2807 Riviera
Post by wanderer »
I'm looking into sprucing up the dashboard on my boat. I'm looking at the Sierra Lido series gauges. I priced out all the gauges and it would be a little under $600, and that seems too cheap and easy. Is there any reason these wouldn't just be a simple swap?
Example:
https://www.overtons.com/sierra-lido-6- ... lsrc=aw.ds
Re: Carver 2807 Gauges Upgrade
You have to ensure the resistance range of the senders on the engine, fuel tank, etc. match the gauge resistance spec for the oil pressure, temp, and fuel level. Tachs, volt gauge, sync, etc. don't matter as long as the tachs are designed for inboard/sterndrive gasoline application.
