There is a button above each of the ignition cylinders. What is it's purpose? On my boat - they buttons appear to do nothing. I had expected them to be a kill switch.
Purpose of White Button above Ignition Key
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Fun times on the 1988 Carver Santego 30
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: Purpose of White Button above Ignition Key
Not sure, maybe circuit breakers?
Yup....that is what I believe them to be also......one for each switch circuit.
They are ignition circuit breakers. They won't pop/trip unless there is a problem with the circuit; high load, short, etc. (if they're working properly)
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
We had those on our Mariner. We were taught to push it to start the engines. It silenced the buzzing sound.
- JimN
- Vessel Info: '89 Carver Santego 38
- Been thanked: 3 times
They are circuit breakers and they can fail, over time, without excessive load but still had multiple tripping events. I replaced those on a friends' Carver because they would trip whenever they felt like it and when I checked the current, it wasn't high- maybe 15A.
If they trip frequently, do a current test by turning off all accessories that are controlled by the ignition switches and turn each on, separately. If something shows high current, address that separately and move on, making notes of the current draw for each. That way, you'll have a kind of baseline to use in the future.
