The latches for the compartments fail to return to center which causes the compartment doors to fly open when underway. I believe there was some sort of elastomer that had degraded over time. The interior compartments use the same latch mechanism and they function correctly.
Has anyone found a suitable method of repair? I'll probably cut some small pieces of closed cell foam or silicone to stick in them.
Latch repair for Exterior Compartment Doors
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Fun times on the 1988 Carver Santego 30
