Would anyone have a line on where one might get return springs for door latches. We live in Victoria BC Canada. I have been trying to find a place to make them as I cannot find them around here. Also does anyone know the manufacturer logo on one of the picture
Thank you in advance for any and all ideas
1993 Carver 350 Twin 350XL
Door latches, specifically return springs
- Zootwo
- Vessel Info: 1993 Carver 350 Aft Cabin Twin 350XL gas
Re: Door latches, specifically return springs
Welcome aboard. Take it to a locksmith. That's what I did with a few of mine. Dropped them off and got a call back a couple of days later. All fixed up. I suspect most shops that have been around for a while will have a selection of different springs they can make work.
- Been thanked: 654 times
If the spring isn't broken can you make one more rotation on it to provide more tension?
Is there lube in this slot? If not, it will cause the spring to catch and not allow full travel.
