Rain water entering 366 MY aft cabin.
- Jaybrony
- Vessel Info: 2004 366 motor yacht.
- Been thanked: 2 times
- gmac98004
- Vessel Info: Proud new owner - '98 355 Aft Cabin "Invictus"
6BT5.9M 210hp
Formerly - 1986 - 30' Newport MKIII - Location: Shelter Bay, WA
- Has thanked: 253 times
- Been thanked: 12 times
Re: Rain water entering 366 MY aft cabin.
Are you able to tell us exactly which closet and which part of the closet the leak is coming from?
And also, is it significant enough that it is entering into bilge?
let us know!
Take Care, Greg
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 18 times
I wound up stripping all the old sealant out, and resealed above and below the join, and no more water leaks. I used Sikaflex to seal the joint, and every 2-3 years I would scrape out the Sikaflex and redo it. Just a thought.
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- MyPleasure
- 366man!
- Vessel Info: 2005 Carver 366
- Jaybrony
366man, I know what you are saying. I am literally at my wits end.
- MyPleasure
Just a thought
- 366man!
- Russdee
- Vessel Info: 1984 Carver 3607
twin International 9.0L diesel - Location: Vancouver Island
MyPleasure wrote:Source of the post It took me months to track down where the water was coming from on our 4207, and my Dad always told me that a leak can start a long way from where it pools up. I never did pinpoint the exact location of where the leak started, but pulling all the old sealer out of the rubbing strip that covers the joint where the hull and topsides joined, stopped our leak! I recaulked every cleat, every stantion, ladder fitting and window on the aft end of the boat with no success. I would never have thought that the leak could come from the hull and topside joint, but it sure did.
Just a thought
Good to know.. I have a 3607 that is leaking rain water into the aft cabin underneath the writing table.. The rub rail on my boat seams to be pretty tight and can't see where any removable/replaceable sealant would be
- Been thanked: 1043 times
Russdee wrote:Good to know.. I have a 3607 that is leaking rain water into the aft cabin underneath the writing table.. The rub rail on my boat seams to be pretty tight and can't see where any removable/replaceable sealant would be
Are you talking about the table on the port side?
The portlights back there would be a big suspect, including the one in the aft head. There's a fiberglass "shelf"" under those that would allow water to track aft from the point of the actual leak and then drop down later.
If you haven't already, I would also thoroughly check the stanchions and the cleat to make sure there's no possibility those are allowing water in also.
Water can track along the inside of the hull and start showing up pretty far from the actual leak location. Some of those buggers can be hard to find.
Users browsing this forum: ballewsd@yahoo.com, Google Adsense [Bot] and 336 guests
