89' Santego switch to raw water flush
bobwhorn
Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
Has thanked: 3 times
Post by bobwhorn »
With the small water tanks, I think it is a shame to use fresh water to flush the head. There is an unused thru hull next to the shower sump. Has anyone used that thru hull for flush water?
Bob
Re: 89' Santego switch to raw water flush
Post by tomschauer »
Your boat may have used that thru hull for the raw water flush when new, someone probably changed it over to freshwater flush to eliminate smells and nasty dirty toilet bowls.
If the head was also changed, it may not have an onboard raw water pump, so you need to check that before considering changing.
bobwhorn
Post by bobwhorn »
I figured I would need to add a pump.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Post by ColRon »
That’s where my raw water comes in to flush the head.
Ron
“Escape Plan”
Murray, KY
:usa:
