Carver 350 aft cabin 1994 shaft length
ataylor233
Has thanked: 83 times
Been thanked: 7 times
Post by ataylor233 »
does any know how long the shaft is one of mine is bent and i need to replace it
Re: Carver 350 aft cabin 1994 shaft length
I wouldn't depend on factory spec. Remove the shaft and measure it if you're ordering one or just take it to a good prop shop, they should be able to cut you a new shaft fairly quick. I've seen several owners order based on spec only to find it doesn't match the one on the boat.
