New '88 Mariner 3297 Owner
KipW
Vessel Info: 1988 Carver Mariner 3297
Has thanked: 6 times
Been thanked: 2 times
Postby KipW » May 30th, 2024, 9:26 am
Hi All!
Been snooping around the forums for while now learning the tricks of this boat, it's new to us later last summer. We upgraded from a 25' regal ambassador, absolutely loving the significantly larger size as well as ability to access nearly everything for maintenance (though the v-drives are going to be a pain to change the fluid).
I've already done a number of upgrades including replacing the outside teak ladders with plasteak. I like tinkering with electronics so also done a number of DC electrical upgrades including running a lightweight server on the boat to keep an eye on things such as battery voltage and fuel usage as well as having a local plex server.
Cheers,
Kip
Been thanked: 621 times
Re: New '88 Mariner 3297 Owner
Postby g36 » May 30th, 2024, 10:57 am
Welcome aboard
Has thanked: 57 times
Been thanked: 445 times
Postby waybomb » May 30th, 2024, 2:56 pm
Welcome aboard!
Has thanked: 457 times
Been thanked: 1697 times
Postby Viper » May 30th, 2024, 8:44 pm
Welcome aboard Kip
Users browsing this forum: No registered users and 196 guests
