New stove top
- Chona
- Vessel Info: 1988 Carver 3607
- Has thanked: 6 times
New stove top
- Been thanked: 622 times
Re: New stove top
If you don't have one I would suggest getting one there is do many things you check /verify . Like battery voltage, continuity, switch connections etc.
Looks like canda uses a different wire color red and black instead of the US 120 . I'm guessing your familiar with that.
- Has thanked: 270 times
- Been thanked: 1160 times
Re: New stove top
Stove side, may be an issue since red and Black are normally hot wires which are normal colors for a 220v connection and not 120v. Yellow with green stripe is ground. Take a look at the specs of the stove to confirm it is 120V. Or tell me what the tag says on the black wire. I can clearly see L2 on the red but the tag on the black is hidden. Point is I think you bought the wrong voltage stove.
On a normal 120v wiring of your stove it should be the same colors as the boat. Green varies in green color and even yellow with a green stripe, it's all the same ground wire. The red is not normal for 120v wiring, it should be white.
- waybomb
- CYO Moderator
- Has thanked: 57 times
- Been thanked: 446 times
Re: New stove top
- Chona
Re: New stove top
