1977 Carver 2276 sink water stoage
sdsurf
Vessel Info: 1977 Carver 2276
Has thanked: 3 times
Postby sdsurf » January 26th, 2025, 9:38 am
Good Morning
I have a 1977 Carver 2276 in great condition but missing a few items. It has two sinks, one in the Galley and one in the head. I am missing both water tanks for those. Any idea of what they would be or are spec'd? If not original, what would work...
Mike
Been thanked: 616 times
Re: 1977 Carver 2276 sink water stoage
Postby g36 » January 26th, 2025, 10:43 am
If your talking fresh water they would not generally have separate water tanks. There could be 2 but they would most likely be plumbed together. Otherwise there would be 2 water pumps fills and vents. Have you traced the water lines to the bilges, find your water pump or searched your water fill to some point where a tank would be? If there's not physically one there I would measure the area and look online for a poly tank that would fit in the spot and plumb it in.
If waste water then those would be discharged overboard directly or through a sump pump
Been thanked: 1046 times
Postby km1125 » January 27th, 2025, 1:12 pm
If you do end up needing a tank (or two), make sure you check out greatlakesskipper site. They have tanks from various manufacturers and might have a size that would work for you. They were significantly less expensive than other sources when I needed to replace a couple tanks a few years ago.
