Carver 56" shaft length
- Tksalerno
- Vessel Info: 2006 carver 56 Voyager
- Has thanked: 582 times
- Been thanked: 1213 times
Re: Carver 56" shaft length
- waybomb
- CYO Moderator
- Has thanked: 53 times
- Been thanked: 434 times
When the boat is moving, do you have vibration?
Are the props true?
- Tksalerno
- Tksalerno
- Has thanked: 457 times
- Been thanked: 1675 times
Remove the shaft that's still intact on the other side and set the broken shaft beside it to compare lengths, they might have been the same length but maybe not, I wouldn't assume anything. Something might have been changed in the past like the position of the engines, who knows. If both shafts look like they were the same length then you can use the good shaft to determine what the new length should be. I would recommend replacing both shafts.
- Tksalerno
- waybomb
- CYO Moderator
Tksalerno wrote:Source of the post It sure would be nice to get a measurement from another 2006 Carver 56' to verify the correct length.
Just a thought , have a walk thru some boatyards that deal with larger boats with your tape.......just might come across a model the same as yours, or at least get a better visual idea of what is normal.
Users browsing this forum: Google [Bot] and 23 guests
