2007 Carver 35SS (Super Sport) - remove microwave?
BigBadJohnnyB
Vessel Info: 2007 Carver 36SS
Postby BigBadJohnnyB » January 29th, 2025, 12:21 pm
Hi all,
I just purchased a 2007 Carver 35SS, 3rd owner. I’m trying to figure out how to pull out the microwave/coffee maker combo unit and replace with a more updated convection/air fryer appliance.
There are no obvious mounting/securing screws, nor do I see a trim piece that I can remove - other than the hole cut in the cabinetry itself, this doesn’t appear to be a trim piece, like surrounding the TV or cabinet doors which may reveal screws.
All I see is a black board that seems to just be sitting on top of the microwave. It is not secured, but cut and shaped such that it’s not going anywhere, and I can’t pull it out - although I CAN wiggle it. That being the case, it doesn’t appear to be securing the microwave in place, but probably rather just stopping the microwave from bouncing around in the cavity? I don’t know.
At any rate - any advice on how I can pull this microwave? I have pulled the power from the outlet that’s inside the cabinet directly to the right of the appliance - and when I attempt to pull on the microwave (seems solidly mounted) it’s not as if it is snagging on the cord in any way that I can tell.
Any advice would be SO appreciated!
Has thanked: 582 times
Been thanked: 1213 times
Re: 2007 Carver 35SS (Super Sport) - remove microwave?
Postby bud37 » January 29th, 2025, 1:53 pm
Welcome to the forum. Chances are the black board is screwed from underneath and the micro is screwed to the board from under the board.....that is how mine was. Have a real good look around the screws can be hidden quite well.....good luck
BigBadJohnnyB
Postby BigBadJohnnyB » January 29th, 2025, 1:59 pm
Maybe some pictures would help.
