3607 height
LakeTemisk
Vessel Info: 1987 Carver 3607 aft cabin
Has thanked: 4 times
3607 height
Postby LakeTemisk » February 14th, 2025, 10:16 pm
I am in the process of purchasing a 1987 Carver 3607 aft cabin model. The boat will need to be moved about 400 kms. At the moment, I am trying to find the overall height of this model and not having any luck. It is not possible to do the measuring myself because I live far away. Also, since it is winter, the boat is buried under snow. I am looking for the measurements from the top of the helm on the fly bridge to the bottom keel. If someone would have any information to share, please reach out.
Has thanked: 57 times
Been thanked: 446 times
Re: 3607 height
Postby waybomb » February 15th, 2025, 10:57 am
Welcome aboard!
I can't help you with the height, but does the boat have a radar arch? Hardtop? Radar and other things on top?
If you are considering moving by trailer, they were delivered by the factory with the flybridge removed. Down to the roof of the cabin. Items from the bridge were stored inside the boat and on the foredeck.
Probably cheaper to move the boat via water if possible.
Has thanked: 585 times
Been thanked: 1231 times
Re: 3607 height
Postby bud37 » February 15th, 2025, 3:38 pm
Welcome to the forum......again no help with the measurements but.....boat transporters may have some data on heights if they have moved a year and model like yours. There will be things to remove.
To add make sure that at your destination there will be some way of getting it off the trailer if they don't deliver to the water or block it. My assumption is you are going to lake Temiskaming somewhere, make sure the destination can handle your boat for storage etc down the road. Good luck with your move. that is a nice area.
Been thanked: 1055 times
Re: 3607 height
Postby km1125 » February 16th, 2025, 10:15 am
There are a few members on here who have moved their 3607's and might be able to weigh in.
I did not move mine via road, but can tell you the air draft is about 14' (with no radar arch or hardtop) and the water draft is 38". Remove the props and the rudders and the water draft probably drops to 26".
As noted earlier, when these move via roadways the bridge is removed from the cabin top. This involves the bridge surround, the helm and the bridge seating (three separate structures) and the helm seat. There are multi-pin connectors to disconnect most of the electrical wiring under the helm, but anything added or modified after it left the plant would likely need to be cut and spliced. The controls for throttle, transmission and steerage can be left connected but will need to be unbolted from the helm structure.
LakeTemisk
Re: 3607 height
Postby LakeTemisk » February 19th, 2025, 7:57 pm
Thank you very much everyone for the information. It is greatly appreciated.
Phil
camsaure@aol.com
Has thanked: 25 times
Been thanked: 6 times
Re: 3607 height
Postby camsaure@aol.com » February 20th, 2025, 9:11 pm
I have a 1988 Carver product manual that gives the specs on all 1988 models, I believe 87 would be the same. It gives bridge clearance as 11'9'' without arch, 16'1'' with arch, Draft of 38''. Also beam 12'6'', length 35'7'', waterline length 31'4'', Displacement 18,500 lb. I am sure total height, depending on trailer would vary.
Last October I moved a 3297 1987 Mariner from Western Wisconsin to Arizona, the trip went pretty well. It pulled down the road surprisingly well. After it was loaded on the trailer and hooked to the truck I measured the total height. I parked on level ground, took a straight piece of 1/2 in conduit with a magnetic torpedo level, a tape measure taped to the end, then held it on the highest point across the windshield, keeping it level. Then had someone read the tape measure on the ground. It came out to be 13' 6 and !/2 inches. I put on the paperwork/permits 13'6'' I got by without removing the windshield. For comparison the specs for the 3297 are: bridge clearance 10' 10'' and draft 33''. So I guess you would be about 16 inches or so taller.
Yoeman
Vessel Info: Carver Mariner 32
1988
Gifted to me
Needs work
220 hp
Re: 3607 height
Postby Yoeman » April 18th, 2025, 9:13 am
Can you tell me what trailer you recommend to get my 1988 3297 out of the water
The hull design is odd
I do have a tandem trailer for my 28 Monterey
I only want to bring it out of the water then block it
