Marine Air unit loses prime
- bikeboybob
- Vessel Info: 1991 Carver 38 ft Aft Cabin
- DanM
- Vessel Info: Carver 396
- Has thanked: 5 times
- Been thanked: 33 times
Re: Marine Air unit loses prime
You can do a few things. Make sure the intake is always in the clear water flow, the strainer and hose are clear from slime and debris. If that doesn't fix it you can put a bleeder valve just before the pump intake. If when you bleed the line it fixes the problem you probably have a failing pump or pump impeller which will need to be replaced (easy project). You also could have a scale filled cooling line in the AC unit itself but this is less likely.
Carver 396
SugarSand Tango
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
