If anyone knows where the forward head black water tank is located on a 1991 Carver 3607 Aft Cabin please let me know.
Thank you
3607 Black Water Tank
- 757
- Vessel Info: 1990 3607 Aft Cabin
Re: 3607 Black Water Tank
I had an older ('83) model but if the layout was the same then it is under the aft seat in the dinette.
I replaced mine and when I did I reconfigured the compartment a bit. I used a slightly smaller tank (IIRC, 32 gal vs the 40 gal stock) only because I could get them really inexpensively via greatlakesskipper. I think there's pictures in the 'projects' forum. I also removed the fixed panel towards the steps down to the galley and added hinges so it could be opened and that new extra area used for storage.
EDIT: This is the thread I was referring to:
viewtopic.php?f=13&t=5336&hilit=waste
- CruiserSteve
- Vessel Info: Carver shopping with Aft cabin
- Has thanked: 4 times
- Been thanked: 2 times
[/image]On the older series of 3607 it is located under the settee bench. The bench that is forward facing if seated at it.
