What type of breaker?
ck36
Vessel Info: 2002 Carver 450 Voyager, TAMD74P
Has thanked: 17 times
Been thanked: 4 times
Post by ck36 »
I'm trying to determine what type of breaker originally was used on this panel for the windlass. At some point it was changed over to a 135 amp Bussman surface mount breaker. I'm replacing the inverter and other components and have very limited space to mount everything so I'd like to find a breaker that fits back in the original space.
Re: What type of breaker?
If you have or had a Maxwell freedom 500 windlass or such it may have been one of those big red mushroom shaped button/breaker isolator switches.
ck36
Post by ck36 »
Thanks, that info led me to what used to be there, but unfortunately it doesn't look like a style of breaker that Maxwell uses anymore or anyone else makes.
