I recently purchased a Raymarine E127 chart plotter. Unfortunately it doesn't contain a port to connect a remote buzzer or alarm speaker so I can hear the anchor drift alarm or radar proximity alarm when I'm in the aft berth sleeping.
Has anybody figured out a "work around" for this?
Raymarine E127 Question
- mikeK
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Raymarine E127 Question
Easiest solution is Anchor Watch HD - download it and install it on your smartphone. Then sleep well.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
I'm not sure what you mean by port...
There should be an output wire coming from the e127 that you can wire to a low current draw buzzer. If you want to power a high current buzzer you will need to wire a relay. Look at the wiring documentation for the unit...
Good Luck
Good Luck
