1988 Carver 3067 Santego trimming outdrives
- Mowery1
- Vessel Info: 1995 Carver 280 express
- Has thanked: 1 time
Re: 1988 Carver 3067 Santego trimming outdrives
The boat is in the shop right now getting the starboard outdrive replaced. Impellers replaced in both drives along with gimbals and changing the fluids..Ill check everything out before it goes back into the water..
- Been thanked: 1313 times
Hopefully they may pick up on something while they are working on the drives.....I wouldn't assume anything while working thru a problem....cross things off the list one at a time.
- Been thanked: 1792 times
I assume they are reinstalling the drives? If so, do they know about the trim issue? If not, tell them so they can check the trim limit switch adjustment in case that's the problem. If the limit switches have to be replaced, I find it easier to do without the drives in the way.
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Did you ever get this figured out? I think I have the same problem where the motors are trimmed all the way up but now responding to down trim
Fun times on the 1988 Carver Santego 30
