1988 Carver 3067 Santego trimming outdrives
Mowery1
Vessel Info: 1995 Carver 280 express
Re: 1988 Carver 3067 Santego trimming outdrives
Post by Mowery1 »
The boat is in the shop right now getting the starboard outdrive replaced. Impellers replaced in both drives along with gimbals and changing the fluids..Ill check everything out before it goes back into the water..
Mowery1 wrote:Qr Bbpost The boat is in the shop right now getting the starboard outdrive replaced. Impellers replaced in both drives along with gimbals and changing the fluids..Ill check everything out before it goes back into the water..
Hopefully they may pick up on something while they are working on the drives.....I wouldn't assume anything while working thru a problem....cross things off the list one at a time.
Mowery1 wrote:Qr Bbpost The boat is in the shop right now getting the starboard outdrive replaced....
I assume they are reinstalling the drives? If so, do they know about the trim issue? If not, tell them so they can check the trim limit switch adjustment in case that's the problem. If the limit switches have to be replaced, I find it easier to do without the drives in the way.
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Post by theorifice »
Did you ever get this figured out? I think I have the same problem where the motors are trimmed all the way up but now responding to down trim
Fun times on the 1988 Carver Santego 30
