Carver 3207 Revised - 2015 projects & bow thruster
Topic author
Mkemper
Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG]
Been thanked: 8 times
Re: Carver 3207 Revised
Postby Mkemper » March 4th, 2013, 7:16 pm
waybomb wrote:Are those the engine room vents? And you're blocking off the engine room from them? At least that's what it looks as if is happening there.
Yes. If you notice the square cut out in the floor that Leeds to the engine compartment. This is a sealed compartment in which has a negative pressure while underway. (Positive pressure with the blower motor on) This is achieved through the venturi effect created by the louvers. Because of this, this area will need to be sealed. The toe kick and bump out is to maintain this passage for the air to be pulled out of the engine compartment. Also the cabinet will only occupy a portion of the space.
Good call this could have been easily over looked
Topic author
Mkemper
Postby Mkemper » March 7th, 2013, 1:01 pm
Some before and afters of the refinished name plates
alexander38
Vessel Info: La Dolce Vita
1987 3607 aft cabin
Postby alexander38 » March 10th, 2013, 7:32 am
Hey Matt, Yes the suits and a mask are a must have, Not having a out shop like yours I'll stick to the shop the marina is letting me use while my boat is on hard. My platform is almost ready for fairing and gel-coat. Blister repairs are also underway, She had a few I'll keep y'all posted.
What did you restore the name plates with ?
Topic author
Mkemper
Postby Mkemper » March 10th, 2013, 2:50 pm
alexander38 wrote:Hey Matt, Yes the suits and a mask are a must have, Not having a out shop like yours I'll stick to the shop the marina is letting me use while my boat is on hard. My platform is almost ready for fairing and gel-coat. Blister repairs are also underway, She had a few I'll keep y'all posted.
Tony
I had the plates power coated. I did however redo the gold lettering with a spray paint. There was not any available in power coat that has a gold shin to it.
You will have to start a post on your project!
Topic author
Mkemper
Postby Mkemper » March 10th, 2013, 2:52 pm
This weekend accomplishments
Installed the last gauge and did a lot of wiring. Still a lot more to do
Installed the door and freed up the 110 volt wiring so that the new panel location would work
Put a coat of sanding sealer on the stairs
alexander38
1987 3607 aft cabin
Postby alexander38 » March 16th, 2013, 5:09 pm
Matt you're right I'll have to get a post up and going, your salon is going to look great. :down:
Topic author
Mkemper
Postby Mkemper » March 16th, 2013, 9:33 pm
Cut the wood last night and assembled today in the boat. Still need to trim it out.
Image[list=][/list]
alexander38
1987 3607 aft cabin
Postby alexander38 » March 17th, 2013, 7:01 am
lookin' good :worthy:
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » March 17th, 2013, 9:25 am
Did you build those shelves in place or are they modular? Can you take them out if access behind is needed?
They look great.
'99 404 CPMY
SeaDragon
Topic author
Mkemper
Postby Mkemper » March 17th, 2013, 9:43 am
AaHubb wrote:Did you build those shelves in place or are they modular? Can you take them out if access behind is needed?
They look great.
Yes they are two units that can be pull out for acess. I have not attached them yet. The bottom kick plate will screw into the base and attach to a nailer on the floor. The top piece will have screws that attach the top. By utilizing these areas the screw will not be that visible. It's kind of hard to explain but I will post some pic's when I get to that step.
Users browsing this forum: No registered users and 51 guests
