Carver 3207 Revised - 2015 projects & bow thruster
Topic author - Deck Hand
- Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG] - Been thanked: 8 times
Re: Carver 3207 Revised
Installed the trim around the shelves. Have to cut the top piece yet. TV will go in the big section
Put a coat on the stairs. Trying to decied if I should put a non-skid additive or get some non-skid pads to put down when we a swimming
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
SeaDragon
Ready for a finish!
Hooked up the Batteries to see how the new panels light looked
Ready to go in this Wednesday
- Has thanked: 53 times
- Been thanked: 425 times
- iceman3500
- Vessel Info: 1987 Carver 3207
iceman3500 wrote:Is that just one piece of carpet? If not, what did you do for the hatches? The cabinets turned out awesome. You mention you didn't want any electrical below decks. Would it be a problem wiring up a 12 volt car amp, etc under there? The wife will lose her mind if I bolt any electronics visible inside the salon. Thanks.
Yes just one piece of carpet. You just need to roll it up to gain access to the hatch. In regarding the electrical what I meant was that behind the forward large section for the TV is the chase for the venting for the engines. I did not want to put a electrical outlet in that section that would protrude into this vent chase. So a ran a pvc pipe chase (with blk cap) through the electrical panel section to the other shelving section in which I have a plug.
Different boat but same setup
After
Green carpet just like you see in Brady bunch household
After
