Carver 38ss Anchor
Peter
Vessel Info: Carver 38ss 2007
Has thanked: 23 times
Been thanked: 7 times
Carver 38ss Anchor
Post by Peter »
Hi guys
I need to run about 80- 100meters for 10mm chain on my anchor it has about 40m at the moment does anyone know if i can
A, splice a rope to the end of the existing chsin
B, swap chain to a longer chain will the winch be up to the job ?
Its a Maxwell code P11112
Any ideas guys ?
Re: Carver 38ss Anchor
You should be ale to go all chain on the Freedom 800. Has to be the correct chain though; 5/16" G40 if I remember correctly. The 800 can pull a total weight of 364kg of rode and anchor. Yes you can splice rope onto the chain. Use 5/8" 3 strand.
Been thanked: 248 times
Post by mjk1040 »
Viper has all my reply's! Darn!
Peter, we have a freedom 800, boat weighs around 18,000 all loaded and it is all chain,believe it is the same size chain Viper said, about 175' when we pulled it out to paint the depths on it.....all good......... :beergood:
Peter
Post by Peter »
Thanks all
