50 amp female to a 30 amp male
buster53
Vessel Info: 2001, Carver 356
Been thanked: 261 times
Re: 50 amp female to a 30 amp male
Postby buster53 » September 24th, 2018, 6:59 pm
buster53
Postby buster53 » September 24th, 2018, 7:12 pm
I can promise you, VA is no stranger to stifling heat and 90% plus humidity. Not too bad this past summer, but July and Aug can get downright ugly around here.
Been thanked: 615 times
Postby g36 » September 24th, 2018, 7:35 pm
Been thanked: 1043 times
Postby km1125 » September 24th, 2018, 8:24 pm
buster53 wrote:Source of the post I can promise you, VA is no stranger to stifling heat and 90% plus humidity. Not too bad this past summer, but July and Aug can get downright ugly around here.
I've lived there. Honestly, I don't think it can compare to St Louis, much less MS.
Serendipity
Vessel Info: 1998 Carver 405
Has thanked: 234 times
Been thanked: 38 times
Postby Serendipity » September 25th, 2018, 7:46 am
Yes indeed km1125 I am in Mississippi. I have had temps in the 90's on Christmas Day here before. So A/C is a must for the living area and helm and area under the hard top.
So yesterday I reached out to a company who can supply me pigtails for my current shore power cords for only $99 plus tax.
I also reached out to an electrician to come to the slip and giive me an estimate.
Generator is a 10,000 watt Kohler 10E with 700 now. I bought it with 611 hrs. When I load it down with everything fridge, lights and both a/c's running. It is showing about a 25% load on the panel. So I would think it could carry a 3rd 16kbtu? 80 to 85% of the time will be on shore panel though.
The panel even has a breaker for the 3rd unit.
Thanks for the info and ya are the bomb.
Postby g36 » September 25th, 2018, 10:34 am
sounds like a plan and the 10 e will have no issues running anything plus the 3rd ac. my 405 like yours with 10e and set up for third ac which makes having the aft cabin great to sleep in. even with everything running i may approach 80% of its rating nice to have the larger genset.
i know you had a lost your boat keys in a post awhile back what did you eventually do? obviously your back boating. just wondering.
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » September 25th, 2018, 6:17 pm
Serendipity wrote:Source of the post I also reached out to an electrician to come to the slip and giive me an estimate.
Just a reminder, make sure he is current with marine wiring practices to be safe.
Has thanked: 268 times
Been thanked: 1153 times
Postby Midnightsun » September 25th, 2018, 6:33 pm
Definately go for dual 125v 50a if the marina is picking up the bill. On a 16 mile landlocked lake it's not like you will be travelling to several other marinas when you can get home in less than 2 hrs at idle speed form the farthest part of the lake. ;-) Hopefully he is familiar with Marine electrical. 125v 50 amp requires much heftier wires than 125/250 and as mentioned the plugs are not compatible with each other.
Serendipity
Postby Serendipity » September 26th, 2018, 10:19 pm
Electrician does my flip houses so I trust him as he is very knowledgeable. He is currently working on a new luxury subdivision in my area wiring new construction.
Naturally he is not as in tune to marine applications as ya are so that is why I ask here first.
So he stopped by and found a Marico EEL pigtail I did not even realize I had in a cubby hole. A Marinco p30-503 EEL 50A-125V Female to 30A-125V Male Pigtail adapter.
It works perfect and is running both my A/C's and I have ordered another pigtail like it.
One of you nice guys gave me a link to order new ignition switches and I ordered from the link. Both switches were $16 a piece. I installed them and they worked flawlessly. They are the basic 3 prong type.
So life is good right now. I just need time to clean her up and moisturize the wood among other things.
Here are some pics of her finally resting in her slip. I reinstalled the eisenglass panels after taking these pics.
Postby Midnightsun » September 27th, 2018, 5:39 am
Glad to hear everything worked out for you, must be nice after all the work to get her there. Have fun and enjoy the boat.
Return to “Electrical”
