Hull Crack Question
swodog6289
Vessel Info: "Open Arms"
36ft Carver 3607 Aft Cabin
Hull Crack Question
Post by swodog6289 »
1986 Carver 3607.
Got a place on the stern that looks lighter than the paint around it so I figured it had been a repair job. This weekend I noticed the bottom had a small crack across the bottom.
I'm going to put this repair in "Urgent" column and get someone out quick as I would think any crack you can visibly see should be repaired quick since you probably wouldn't want any water intrusion.
It's pretty high off the water line (at least 2 1/2 feet and at the very bottom of the off color spot which I would imagine is a repair job.
Wanted to confirm with the Carver Gurus on this one that it should be repaired ASAP.
Been thanked: 492 times
Re: Hull Crack Question
Post by waybomb »
You have cored sides, so, yes, get it fixed correctly or the core will become saturated.
swodog6289
Scheduled my repair folks today. Will post what happens.
