Hull Crack Question
Topic author
swodog6289
Vessel Info: "Open Arms"
36ft Carver 3607 Aft Cabin
Hull Crack Question
Postby swodog6289 » July 21st, 2014, 2:57 pm
1986 Carver 3607.
Got a place on the stern that looks lighter than the paint around it so I figured it had been a repair job. This weekend I noticed the bottom had a small crack across the bottom.
I'm going to put this repair in "Urgent" column and get someone out quick as I would think any crack you can visibly see should be repaired quick since you probably wouldn't want any water intrusion.
It's pretty high off the water line (at least 2 1/2 feet and at the very bottom of the off color spot which I would imagine is a repair job.
Wanted to confirm with the Carver Gurus on this one that it should be repaired ASAP.
Has thanked: 53 times
Been thanked: 425 times
Re: Hull Crack Question
Postby waybomb » July 21st, 2014, 7:25 pm
You have cored sides, so, yes, get it fixed correctly or the core will become saturated.
Topic author
swodog6289
Postby swodog6289 » July 22nd, 2014, 2:49 pm
Scheduled my repair folks today. Will post what happens.
