Broken wire at alternator
- Craig_B
- Vessel Info: 1988 Carver Santego 3067
- Has thanked: 144 times
- Been thanked: 13 times
Had to change the float switch for the bilge pump and while I was crammed into the engine bay I noticed the main battery wire to the starboard engine alternator has rotten away.
I assume since it was already installed it will be ok to repair and reconnect it?
This is my first twin engine boat so I am being overly careful and asking lots of questions before doing any repairs that may have unexpected results.
If anyone can briefly describe how the dual alternators work that would also be helpful. Do they just work together in parallel?
Thanks.
https://www.flickr.com/photos/giarc_dranrab/albums/72157707558217844
The rest of our picture albums.
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Borken wire at alternator
Good catch by the way.... They play together nicely.
- Been thanked: 1043 times
Craig_B wrote:Source of the post
Yes, they both just work together to charge the battery (-ies). If you have a 1-2-all battery switch, then they are only charging the battery selected unless you have a VSR - voltage sensing relay - which would connect other batteries while they are being charged.
Sometimes having two alternators charging will mask a bad one, as the voltage will be "normal" while the engines are running even with one dead alternator (or broken wire which it seems you have). The trick is to force yourself you periodically alternate which motor you start first and check voltage on the meter before you start the other one. Then you know each engine is capable of charging.
- Craig_B
km1125 wrote:Craig_B wrote:Source of the post
That's a Great idea. I Will definitely do that the next couple of times out.
- Craig_B
Re: Broken wire at alternator
Both alternators are now charging.
Users browsing this forum: No registered users and 79 guests
