Broken wire at alternator
Craig_B
Vessel Info: 1988 Carver Santego 3067
Has thanked: 144 times
Been thanked: 13 times
Post by Craig_B »
Took our 1988 Santego out for its first real run since we purchased it this spring.
Had to change the float switch for the bilge pump and while I was crammed into the engine bay I noticed the main battery wire to the starboard engine alternator has rotten away.
I assume since it was already installed it will be ok to repair and reconnect it?
This is my first twin engine boat so I am being overly careful and asking lots of questions before doing any repairs that may have unexpected results.
If anyone can briefly describe how the dual alternators work that would also be helpful. Do they just work together in parallel?
Thanks.
Re: Borken wire at alternator
Just disconnect your battery power.....make sure that cable has no juice before you reconnect with a new end ( test it, dvm )....that way no sparks or surges.. :-O
Good catch by the way.... :down: They play together nicely.
Craig_B wrote:Qr Bbpost
Yes, they both just work together to charge the battery (-ies). If you have a 1-2-all battery switch, then they are only charging the battery selected unless you have a VSR - voltage sensing relay - which would connect other batteries while they are being charged.
Sometimes having two alternators charging will mask a bad one, as the voltage will be "normal" while the engines are running even with one dead alternator (or broken wire which it seems you have). The trick is to force yourself you periodically alternate which motor you start first and check voltage on the meter before you start the other one. Then you know each engine is capable of charging.
Craig_B
Post by Craig_B »
That's a Great idea. I Will definitely do that the next couple of times out.
Craig_B
Re: Broken wire at alternator
Post by Craig_B »
Put a new terminal end on the broken wire and hooked it back up.
Both alternators are now charging. :-D
