Bedding a front windshield
Topic author
SomeDayCame
Vessel Info: 2002 57' Carver 570 Voyager
Postby SomeDayCame » September 19th, 2014, 10:29 am
2002 57' Carver front tinted middle windshield is loose. I need to rebed but am not sure how to go about it. I figure I will take the shield off, cut out the old sealant and then rebed. What type of sealant is recommended. Does anyone have suggestions on the right way to do this?
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Bedding a front windshield
Postby Lyndon670 » September 19th, 2014, 5:18 pm
My first thought would be 3M 5200 as it is permanent, but then I'm thinking maybe 4200 as it is semi permanent - just in case you have to ever replace the glass.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
glazingguru
Vessel Info: 1995 Carver 355 Aft Cabin
Postby glazingguru » September 23rd, 2014, 9:12 am
I would suggest a double sided foam glazing tape. They used to use a butyl tape on them but it oozes out of the edges and is a sticky black mess. After you re-bed the glass in glazing tape, you could go around the perimeter with a silicone bead. To keep the silicone bead looking nice start with a very clean surface and mask both sides of the sealant joint,
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » September 24th, 2014, 7:38 am
Tithe double glaze foam tape is factory OEM. I am in the process of doing my port pilot house glass. The OEM tape is junk and will shrink in heat, depending on your climate. Overtime you will be in the same situation you are in now. The 3M adhesives are like automotive windshield glues and will secure and seal better for a longer period of time (or permanent). Plus way more user friendly with a caulking gun than strips of tape. JMHO.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Has thanked: 53 times
Been thanked: 426 times
Postby waybomb » September 24th, 2014, 12:49 pm
I am a fan of BoatLife caulk and careful masking for this type of job. Always comes out water tight and looking good.
Topic author
SomeDayCame
Postby SomeDayCame » October 4th, 2014, 2:44 pm
Thanks for the reply's and helpful tips.
Users browsing this forum: No registered users and 96 guests
