356 aft cabin head filter location
- barbarab
- Vessel Info: Carver 356 2002
- Has thanked: 1 time
Hi all! I'm certain I need to change the head vent filter for the aft head. I've located the holding tank under the aft berth but I can't locate the vent filter.. we have a 2002 356 aft cabin. thanks!
Update: I did find the aft holding tank under the rug outside the entrance to aft head. The filter ended up being under the large air conditioning hose. It was completely out of sight, kudos to my brother for tracking it down. Thanks everyone. This forum is amazing.
Re: 356 aft cabin head filter location
my 1998 355 didn't have one. I had to add it. You may not have one either.
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
I have 2002 as well, my 410 did not have one either as verified by the build sheets
- Barb
- Vessel Info: 2002 Carver 356 aft cabin
Thanks for the replies. I was just assuming it had one because we changed the forward head vent filter
last year and the schematics from carver show one..
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Ok, are you sure the holding tank is under the aft berth? I thought that was the water tank. If you pull up your rug and open up those bilge covers, pretty sure you will find the holding tank ther and last time I looked, I thought I saw an in-line filter
- Barb
Thanks for your response. I will pull up the rug up and have a look! much appreciated. Barb
Good point buster. The water tank is under the bed and the waste tank under the floor near the front of the aft cabin just outside the shower area.
- barbarab
You were absolutely correct! Thanks so much. We were able to eventually follow the pipes and find the head filter under the air con hose, under the aft bunk. Crazy.
