356 aft cabin head filter location
barbarab
Vessel Info: Carver 356 2002
Postby barbarab » August 9th, 2019, 10:41 am
Hi all! I'm certain I need to change the head vent filter for the aft head. I've located the holding tank under the aft berth but I can't locate the vent filter.. we have a 2002 356 aft cabin. thanks!
Update: I did find the aft holding tank under the rug outside the entrance to aft head. The filter ended up being under the large air conditioning hose. It was completely out of sight, kudos to my brother for tracking it down. Thanks everyone. This forum is amazing.
Has thanked: 324 times
Been thanked: 595 times
Re: 356 aft cabin head filter location
Postby tomschauer » August 9th, 2019, 10:49 am
my 1998 355 didn't have one. I had to add it. You may not have one either.
darrenlife
Vessel Info: 2002 Carver 410 Sport Sedan
Been thanked: 36 times
Postby darrenlife » August 9th, 2019, 12:56 pm
I have 2002 as well, my 410 did not have one either as verified by the build sheets
Barb
Vessel Info: 2002 Carver 356 aft cabin
Postby Barb » August 9th, 2019, 1:26 pm
Thanks for the replies. I was just assuming it had one because we changed the forward head vent filter
last year and the schematics from carver show one..
buster53
Vessel Info: 2001, Carver 356
Been thanked: 261 times
Postby buster53 » August 9th, 2019, 5:37 pm
Ok, are you sure the holding tank is under the aft berth? I thought that was the water tank. If you pull up your rug and open up those bilge covers, pretty sure you will find the holding tank ther and last time I looked, I thought I saw an in-line filter
Barb
Postby Barb » August 9th, 2019, 5:43 pm
Thanks for your response. I will pull up the rug up and have a look! much appreciated. Barb
Postby tomschauer » August 10th, 2019, 1:22 am
Good point buster. The water tank is under the bed and the waste tank under the floor near the front of the aft cabin just outside the shower area.
Postby tomschauer » August 10th, 2019, 1:23 am
Probably dont have a filter but definitely worth a look!
barbarab
Postby barbarab » September 3rd, 2019, 5:13 pm
buster53 wrote:Source of the post Ok, are you sure the holding tank is under the aft berth? I thought that was the water tank. If you pull up your rug and open up those bilge covers, pretty sure you will find the holding tank ther and last time I looked, I thought I saw an in-line filter
You were absolutely correct! Thanks so much. We were able to eventually follow the pipes and find the head filter under the air con hose, under the aft bunk. Crazy.
Users browsing this forum: No registered users and 197 guests
