I am the new (old) guy
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Has thanked: 5 times
Been thanked: 7 times
Postby Youghster » September 4th, 2019, 5:04 pm
We took delivery of a 95 Santego 310 a couple weeks ago and we are getting to know her. So far the problems have had solutions but that can't last. I expect I will be asking for help soon and often and I will certainly share what I can. I do have a little experience with Chris Craft, a 57' mahogany runabout and a 28' Catalina from 1980. I hate to see her go, but I think we are going to be really happy on this Carver.
Has thanked: 580 times
Been thanked: 1210 times
Re: I am the new (old) guy
Postby bud37 » September 4th, 2019, 5:32 pm
Welcome to the forum and Carver.......I'm thinking if you kept up a woody and the Cat then your Carver should be a snap...... :-D
Has thanked: 53 times
Been thanked: 428 times
Postby waybomb » September 4th, 2019, 7:41 pm
Welcome aboard!
Has thanked: 456 times
Been thanked: 1671 times
Postby Viper » September 4th, 2019, 8:32 pm
Congrats and welcome aboard. My first boat was a '61 Chris Connie. She was a great boat and I'm told she's still going strong.
vineyardgray
Has thanked: 125 times
Been thanked: 32 times
Postby vineyardgray » September 4th, 2019, 10:07 pm
Welcome - we can always use a new Santego owner! Great boats - post some pics when you can?
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Vessel Info: 2022 Stingray 182 SC
Been thanked: 467 times
Postby RGrew176 » September 5th, 2019, 3:36 am
Welcome Aboard. Santegos are pretty nice boats. Good luck with yours.
Been thanked: 615 times
Postby g36 » September 6th, 2019, 8:10 am
welcome glad you found us
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Postby Youghster » September 10th, 2019, 4:49 pm
Thanks to all for the warm welcome. And now here comes one of those problems..... We finally took up the snap together "hardwood floor" that a previous owner installed. There was no access to the floor hatches and I just had to have a look at the shower box and waste tank and fresh water tank; especially since the tank level indicator does not work on the holding tank. I found that the fresh water tank has swelled up and pushed up the access hatch (plywood) so that it no longer lays down securely. The tank is flexible and does not leak, but how in the dickens does one get the bulge out of the top of it ?
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » September 10th, 2019, 7:13 pm
I assume its a plastic tank. If so here is an idea, no idea if it will work, but its something I would try if it was my problem.
Drain the tank. Plug the vent, make sure the fill is closed tight, pull the supply off the pump and introduce a vacuum to the tank. If you have any access to an a/c - refrigeration vacuum pump that would be ideal. I would try heating the top of the tank with a heat gun while under vacuum.
Youghster
Vessel Info: 1995
Santego 310
Small Lake Use
Postby Youghster » September 10th, 2019, 7:49 pm
Thanks - that is a fine idea. I will try to get that project underway before we winterize. Our season ends mid September. Mountain lake boating :-(
Users browsing this forum: No registered users and 280 guests
