444 CMY Power Question
jmalgieri
Vessel Info: 2003 44 Carver Cockpit Motor Yacht
Sereni-Tee
Haverstraw, NY
Postby jmalgieri » November 2nd, 2014, 2:18 pm
I want to change the 2 50 amp 125volt receptacles to one 50 amp 250 volt receptacle so that I do not have to use an adapter all the time. Any idea on how I would wire this? Do I gang the 2 lines together? Any help would be greatly appreciated.
SHEMP
Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht.
Been thanked: 4 times
Re: 444 CMY Power Question
Postby SHEMP » November 7th, 2014, 8:08 am
Hi there ,
I have a single 50 amp Shore cord on my 456. I understand why you want to make your change but highly recommend that you hire a Marine Electrician to do the job. The factory cabling probably runs directly to your 120V panel in the Salon .
The probability of an Electrical fire is quite high if the job is not done properly .
Also , on a future Survey , The Surveyor will notice any work that is not safe. You might have to redo any work that is not to ABYC Standards.
Victor
Return to “Electrical”
Users browsing this forum: No registered users and 54 guests
