444 CMY Power Question
jmalgieri
Vessel Info: 2003 44 Carver Cockpit Motor Yacht
Sereni-Tee
Haverstraw, NY
Post by jmalgieri »
I want to change the 2 50 amp 125volt receptacles to one 50 amp 250 volt receptacle so that I do not have to use an adapter all the time. Any idea on how I would wire this? Do I gang the 2 lines together? Any help would be greatly appreciated.
SHEMP
Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht.
Been thanked: 4 times
Re: 444 CMY Power Question
Post by SHEMP »
Hi there ,
I have a single 50 amp Shore cord on my 456. I understand why you want to make your change but highly recommend that you hire a Marine Electrician to do the job. The factory cabling probably runs directly to your 120V panel in the Salon .
The probability of an Electrical fire is quite high if the job is not done properly .
Also , on a future Survey , The Surveyor will notice any work that is not safe. You might have to redo any work that is not to ABYC Standards.
Victor
