1980 Voyager 3326 ... Update
Re: 1980 Voyager 3326 ... Update
Austinorson wrote:Qr Bbpost ....I am carefull not to over fill, any engine, does that cause excess oil pressure?
No, in fact quite the opposite. The oil will foam up and get aerated by the crank if there's too much in the sump, the pump can't move oil in that condition. This can reduce pressure, cause complete pressure loss, overheating, foul plugs, blow seals, cause excessive exhaust smoke, etc. Because of it's influence on engine performance, checking for an overfilled sump is on the list of a good tech's first things to check when diagnosing runnability issues.
Austinorson
Vessel Info: 1980 3326 Voyager
1989 Chaparral 187xl
Has thanked: 10 times
Been thanked: 2 times
Post by Austinorson »
That is great information. I always wondered , but it makes sence.
Thx
Been thanked: 1114 times
Not so much excessive oil pressure, but you will get splashing from the crankshaft which will foam the oil and cause LOW oil pressure.
On the comment "I didnt allow enough time for the oil to drain back to the pan"... This should really never be an issue. Think about it... when the engine is running full tilt, the oil needs to be constantly "draining back to the pan" or you would run out of oil. If you check it immediately after stopping, it might be lower than if you wait, but it should not be below the "fill" line (not the "full" line!)
Austinorson
Yes there has to be oil in the pan . As it operates , draining back then pumped out again...thx
