Hi All
talieho
Vessel Info: 1986 motor cockpit
Hi All
Postby talieho » March 27th, 2020, 7:05 pm
Bought my Carver motor cockpit last season but am newer to the forum. Appreciate all insight and advice so far.
Be Safe!!
Has thanked: 456 times
Been thanked: 1671 times
Re: Hi All
Postby Viper » March 27th, 2020, 7:07 pm
Glad to have you aboard.
hurleypooper
Vessel Info: Carver 3007 I think the serial number is #cbq 001590581-81
maybe9
Re: Hi All
Postby hurleypooper » March 27th, 2020, 8:00 pm
Ia m trying to find out info on my 3007 Carver cant seem to find the hull plate---Help
Been thanked: 615 times
Re: Hi All
Postby g36 » March 27th, 2020, 9:32 pm
Hi welcome . It should be on the transom starboard side it is possibly also mounted in the engine bay on the stbd stringer around or under the engine. If not found you could call carver and let them offer their suggestions on where they mounted it on your boat.
Has thanked: 324 times
Been thanked: 595 times
Re: Hi All
Postby tomschauer » March 27th, 2020, 10:20 pm
as mentioned, starboard side, not a "plate" should be "pressed" in the fiberglass, under the swim platform.
Vessel Info: 2022 Stingray 182 SC
Been thanked: 467 times
Re: Hi All
Postby RGrew176 » March 28th, 2020, 2:46 am
Welcome Aboard.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Re: Hi All
Postby pepmyster » March 28th, 2020, 6:51 am
Welcome!!!!!!!!!!!!!
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 390 times
Re: Hi All
Postby Cooler » March 29th, 2020, 1:33 pm
Hurley - It should start with CDRN. That is the identifier for Carver Mfg. Might be painted on the transom, inside the engine compartment. It will end with a 2 digit number that discloses the model year. It is also listed on your title. Good luck. 8-) er
Cooler By The Lake
PCOMT
Vessel Info: "BRAKSPEAR"
1981 3007 Aft Cabin
Has thanked: 4 times
Re: Hi All
Postby PCOMT » April 2nd, 2020, 2:00 pm
My 3007 has it on the aft deck, starboard side, near the rubber strip. I can see it from the swim grid, about head high.
It is in the gel coat and not too easy to see.
Pcomt
Peter
Retired, but not tired, Looking forward to getting out there!
Re: Hi All
Postby tomschauer » April 6th, 2020, 9:48 pm
Just thought of this, but you hull ID number should also be on your title and registration/ cg documentation papers.
:banghead:
Users browsing this forum: No registered users and 331 guests
