Hi All
talieho
Vessel Info: 1986 motor cockpit
Hi All
Post by talieho »
Bought my Carver motor cockpit last season but am newer to the forum. Appreciate all insight and advice so far.
Be Safe!!
Re: Hi All
Glad to have you aboard.
hurleypooper
Vessel Info: Carver 3007 I think the serial number is #cbq 001590581-81
maybe9
Re: Hi All
Post by hurleypooper »
Ia m trying to find out info on my 3007 Carver cant seem to find the hull plate---Help
Re: Hi All
Post by g36 »
Hi welcome . It should be on the transom starboard side it is possibly also mounted in the engine bay on the stbd stringer around or under the engine. If not found you could call carver and let them offer their suggestions on where they mounted it on your boat.
Re: Hi All
Post by tomschauer »
as mentioned, starboard side, not a "plate" should be "pressed" in the fiberglass, under the swim platform.
Re: Hi All
Post by RGrew176 »
Welcome Aboard.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: Hi All
Post by pepmyster »
Welcome!!!!!!!!!!!!!
Been thanked: 414 times
Re: Hi All
Post by Cooler »
Hurley - It should start with CDRN. That is the identifier for Carver Mfg. Might be painted on the transom, inside the engine compartment. It will end with a 2 digit number that discloses the model year. It is also listed on your title. Good luck. 8-) er
PCOMT
Vessel Info: "BRAKSPEAR"
1981 3007 Aft Cabin
Has thanked: 4 times
Re: Hi All
Post by PCOMT »
My 3007 has it on the aft deck, starboard side, near the rubber strip. I can see it from the swim grid, about head high.
It is in the gel coat and not too easy to see.
Pcomt
Peter
Retired, but not tired, Looking forward to getting out there!
Re: Hi All
Just thought of this, but you hull ID number should also be on your title and registration/ cg documentation papers.
:banghead:
