Engine room bilge cleaning
- Peter3607
- Vessel Info: 1998 Carver 500 CMY
1989 Carver 3607 Aft Cabin - Location: Ontario
- Has thanked: 29 times
- Been thanked: 2 times
- Been thanked: 1043 times
Re: Engine room bilge cleaning
However, if/when you do get it cleaned by someone else, make sure you spend some time after they're finished looking around the compartment for anything that might have been broken or dislodged when they were in there. I had someone clean mine (also a 3607) many years ago and found several things that ended up broke (like the bilge pump float switch!).
Certainly does make it nicer to work in there after it's clean though!!
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
What has been successful for me, I spray the bilge with a natural spray and let it sit. Then scrub where I can with a brush. I then bring the power washer in and you would be surprised how clean it will get.
Just need to be careful you don't break anything, but so far I have not had an issue. The bilge pumps will remove most water to a certain point, then I get in there with a shop vac with an extension on the end to remove the rest of the water and guck. Leave the floor open till the bilge dries out, doesn't take long.
Works great for me over the years and the bilge is very clean. Just need to stay on top of it. I also put absorbent towels under the engines to catch drippings etc. to help stay ahead of it.
Greg
- Peter3607
Tireless wrote:Source of the post I have a hard time getting down there to clean the bilge as well ay 6'4" 265 Lbs.
Greg
My only concern to this would be pumping oily bilge water directly into the lake. Major fines if caught. I would have to disconnect the bilge pumps and use the shop vac to suck out all the water and dispose properly. Still a tight engine compartment to move around though.
- Tireless
Peter3607 wrote:Source of the post My only concern to this would be pumping oily bilge water directly into the lake. Major fines if caught. I would have to disconnect the bilge pumps and use the shop vac to suck out all the water and dispose properly. Still a tight engine compartment to move around though.
I can see where you are coming from, for sure. Oil is an issue, if thats what is in your bilge then probably using a shop vac is the way to go. Thats why I use the matts under the engine to grab the oil and drippings.
Under the circumstances maybe hiring someone is the best thing to do, for sure. I am not aware of anyone that does this in Ontario, but I am sure they are out there.
Greg
- Has thanked: 268 times
- Been thanked: 1153 times
- Has thanked: 324 times
- Been thanked: 595 times
- Has thanked: 579 times
- Been thanked: 1210 times
Good point nowadays....you put a sheen on the water, that can be grounds for a fine or clean up order. There is an outfit that cleans boats in Ontario, I think they do fire clean ups etc as well....can't remember the name right now, I will post the name if I remember it....maybe someone else can post if they know.
In any case, clean with hot water and the full strength green stuff...towels and broom handles to push the towels around then vac up. I agree about having people climbing around stepping on who knows what....something to avoid there. You don't need tremendous amounts of water, not nearly enough to trigger the bilge pumps if you start with a dry bilge and do bits at a time.
- Has thanked: 455 times
- Been thanked: 1671 times
The first project on every boat I've bought was to scrub the bilge. Some were worse than others but all had oil, dried out grease, and caked up whatever. My method for cleaning up such caked up messes and get a sparkling result is to go to the dollar store, buy some scrubbing pads, dish washing gloves, and a few different sizes of brushes with different length handles to reach hard to get areas. The product I use to clean with is just a hand cleaner with pumice like orange scented Gojo. The pumice does an amazing job of cutting through thick grime, grease, etc. Scrub with the brushes/pads and rinse the area, vacuum up then move on to the next section. The boat will smell like oranges for a week! If the bilge isn't too bad, a good product in a spray will do.
After this first time scrub, if you keep on top of it every year or two, it'll be easy to keep clean. Put oil absorbing pads under the engines and transmissions and replace annually after oil changes.
While in the bilge, it offers the best opportunity to inspect and familiarize yourself with your hardware and systems. While you're looking, keep an eye out for mold, you don't want to expose yourself or your family to this stuff. It's not COVID but it's not very friendly either and can result in serious health issues. If you see any, usually black, it's something you need to get rid of but need to take precautions and wear proper protective equipment if doing it yourself.
After cleaning, bilge fluids containing ANY petroleum products need to be disposed of properly. This shouldn't be taken lightly if we're to consider the legacy we're leaving for future generations. Some marinas will have a way to dispose of contaminated liquids. For oil contaminated water, really all it takes is dumping the water into a large clear or semi-clear container and letting it sit for a few days. After the oils separate and float to the top, a valve at the bottom of the tank can be used to drain off the water. The oil can then be dumped into the used oil drums most marinas will have for recycling collection. Most marinas have this type or similar setup, if they don't, recommend it, it's easy to put one together.
Users browsing this forum: No registered users and 120 guests
