New Carver Owner
- Pchauvin05
- Vessel Info: 2002 Carver 396 Cummins Diesels
New Carver Owner
We just purchased a 2002 Carver 396. Above all, we wanted a covered slip. The only available covered slip right now has 30amp service. What can we run on 30 amp shore power? More importantly, what can’t we run on only 30 amp?
- Has thanked: 580 times
- Been thanked: 1210 times
- Has thanked: 456 times
- Been thanked: 1671 times
Re: New Carver Owner
You can run a fair bit on 30 amps but not all at once, power management is key. Not ideal but it's doable if a covered slip is important. You just can't run a few high load items at the same time. Try a combination of items and keep an eye on your amp meter to see what you can run comfortably while keeping it under 30 amps. If you have your hot water heater on for example, don't operate the microwave and all of the AC units at the same time.
- Has thanked: 53 times
- Been thanked: 428 times
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
Can't the marina accommodate you? Tell them what you need and see if they can. I told my harbourmaster what I was looking for and he put me in a slip to suit.
Out of curiosity - why the covered slip?
1988 Carver
3867 Santego
PCYC
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- Has thanked: 269 times
- Been thanked: 1153 times
When you say you have only 30A available at the slip, do you have only one outlet or 2 you can use?
Users browsing this forum: No registered users and 334 guests
