Volvo Penta 8.1L exhaust riser elbow pipe plug
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Post by Cliffm »
Question: accessing/checking internal exhaust cavity without removing elbow
On our factory OEM Volvo Penta 8.1L TBI exhaust elbow (no CAT) there is a pipe plug on the top, almost centered over the exhaust riser. Does removing this plug allow "swabbing" the exhaust cavity for moisture?
I don't want to "un-do" a pipe plug that accesses the raw water jacket area.
We had the port engine exhaust riser gaskets replaced last year, and would like to check the std engine.
Cliffm
"the Condo"
VP 8.1Gi-F
Re: Volvo Penta 8.1L exhaust riser elbow pipe plug
Post by Cliffm »
anyone remove this plug for inspections?
Cliffm
"the Condo"
VP 8.1Gi-F
Post by Cliffm »
Searching on-line, I found video of removed VP exhaust elbow, which confirmed that 3/8 pipe plug on top does go to the exhaust cavity for swabbing the inside of passage for moisture/rust.
I'm going to try removing the one on my cracked elbow, as I have nothing to loose taking it out. That will let me know the issues accessing the others.
DanM
Vessel Info: Carver 396
Been thanked: 35 times
Post by DanM »
Following and Thanks
Dan
Carver 396
SugarSand Tango
