110ac panel 2 issue
Mike28
Vessel Info: 1989 32 mid cabi
Has thanked: 3 times
110ac panel 2 issue
Postby Mike28 » May 17th, 2021, 1:37 pm
Hi Everyone,
Last year I bought a 1989 32 Montego.
Everything worked great. We put the boat back in the water about 3 weeks ago and everything seemed to be ok... until I tried to turn the heat on.
Before flipping the A/C/heat breaker "on" I had the main breaket on panel 2 "on" and the volt gauge was reading 110 volts. As soon as I flipped the A/C/heat breaker panel 2 went dead and I can't get it back. I run a Y splitter to the shore power inlets at the boat since my dock only has one 30 amp plug, which has not been a problem before. I tried switching the Y splitter to see if the problem moved to panel 1. The problem was still panel 2 is dead. I removed the panel and checked voltage with a meter and I have no power to panel 2.
The wiring diagram I have from Carver shows "dual shore transfer relays". My question is... wouldn't I only have those if I had a generator? I do not have a generator.
Does anyone know if there are hidden breakers somewhere? I feel like I've looked in every spot but there must be something I'm missing.
Has thanked: 268 times
Been thanked: 1153 times
Re: 110ac panel 2 issue
Postby Midnightsun » May 17th, 2021, 2:01 pm
You're going to have to dig deeper with a volt meter to see if you are getting power to then main panel 2 breaker. If so a defective, breaker may be the cause. Check the wires behind the inlet as they may be getting bad due to arcking/poor connections over time. Things like this do happen after all this time, the boat is 32 years old now.
A good reminder to all with an older boat, check the wires at the inlet connection as these do go bad. Will not hurt the least to remove, cut away a couple inches and reinstall on a fresh lead. Most boat fires originate at this connection.
Welcome to the forum by they way. :captain:
Mike28
Postby Mike28 » May 17th, 2021, 2:16 pm
I checked the back of panel 2 for 110 volts, there is no power at the panel. I pulled the inlet out and checked that connections also. Everything looks great at the inlet and I have 110 coming out of the inlet. Are there any more connection points or splices in the boat somewhere?
Postby Midnightsun » May 17th, 2021, 2:18 pm
Not sure on your boat, maybe some solenoids for automatic transfer? Will let someone else more familiar with your boat take over from here.
Been thanked: 615 times
Postby g36 » May 17th, 2021, 2:39 pm
My 405 has breakers at the shore inlet locations also
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 390 times
Postby Cooler » May 17th, 2021, 3:52 pm
Yep, check for breakers at the cord connection. There may be 2 square covers. One for TV/phone, one with two breakers A & B. Push button type. 8-) er
Cooler By The Lake
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 75 times
Postby chpsk8 » May 17th, 2021, 4:35 pm
I found those breakers on ours this weekend after pulling all of my shore power cords out for the first time. Found 5 inlets. Two were shore power, one for cable/phone and two were breakers. Each one had two 30 amp breakers in them. I need to start keeping a book of all the odd places there are those random breakers!
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » May 17th, 2021, 4:52 pm
Like they have all said ....check the breaker at the shore power inlet where you plug in.
buster53
Vessel Info: 2001, Carver 356
Been thanked: 261 times
Postby buster53 » May 17th, 2021, 5:26 pm
g36 wrote:My 405 has breakers at the shore inlet locations also
I don’t think builders were doing those breakers back in 1989, when the OP’s boat was built.
Has thanked: 324 times
Been thanked: 595 times
Postby tomschauer » May 17th, 2021, 10:23 pm
If you don't have a genny, you wont have the transfer switches. My 1988 27 montego had the 30 amp breaker above the shore power inlet. It was in a cubby, you really had to get down and look up to find it.
I assume you shut off the breaker for the a/c before reconnecting the power.
If you have a single 30 amp power supply at the dock, you most likely wont be able to run the a/c and water heater at the same time.
Users browsing this forum: No registered users and 56 guests
