Kitchen Faucet Replacement
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Postby tonyiiiafl » May 23rd, 2021, 6:50 pm
Original faucets from my 1994 390CPMY needed replacement. Easier to remove the cabinet doors, use the hatch from under the dinette (saved my back!) and removed old faucets. OF course, hole was 1/8” too small, so had to go easy and cut it larger. OF course again, the fittings needed adaptors, Nothing at Home Depot, Lowes had a pair after an hour looking. Nice neat installation if I say so myself!
Has thanked: 455 times
Been thanked: 1671 times
Re: Kitchen Faucet Replacement
Postby Viper » May 23rd, 2021, 10:10 pm
That's interesting Tony, I never saw that combination before; Flair-it fittings used on Qest tubing.
tonyiiiafl
Postby tonyiiiafl » May 24th, 2021, 4:13 am
I have found a lot of that on this boat.
Has thanked: 268 times
Been thanked: 1153 times
Postby Midnightsun » May 24th, 2021, 5:00 am
Something I used to use as well. Worked quite well and was available at the large surface hardware stores. Did a quick search and see they now make fittings specifically for boats/campers, interesting. https://www.flairit.com/
tonyiiiafl
Postby tonyiiiafl » May 24th, 2021, 5:23 am
Hans. Is this for use on Quest?
Postby Viper » May 24th, 2021, 9:18 am
My concern would be reducing flow. Qest fittings are fully ported as the fitting is secured to the outside of the tubing. Flair-it fittings insert into the tubing which reduces the inside diameter. This makes a difference in long runs and flow through multiple fixtures operating at the same time.
Postby Midnightsun » May 24th, 2021, 9:32 am
Not sure if those are good on Quest. It looks like the only item they sell is for 1/2" when most of our boats are on 15mm. Agree with Viper, reduced flow when inserted internally. I did say I used to use for a reason, I now stick with AquaLoc formerly SeaTech. ;-)
https://www.watts.com/aqualock-marine
Used to be availability was an issue however with internet shopping one can easily get exactly what one wants nowadays.
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » May 24th, 2021, 2:42 pm
Well Tony ,looks like you found a useable solution, that looks like it will work just fine......there is always some engineering involved isn't there..... :-D
tonyiiiafl
Postby tonyiiiafl » May 24th, 2021, 6:20 pm
Like I tell the Admiral, once I put it into research and operations, there is NO way that it will fail! Lol!
Been thanked: 615 times
Postby g36 » May 25th, 2021, 11:16 am
tonyiiiafl wrote:Source of the post Like I tell the Admiral, once I put it into research and operations, there is NO way that it will fail! Lol!
Excellent!
Users browsing this forum: No registered users and 85 guests
