Flybridge Throttles
Terra Nova
Vessel Info: 2002 Carver 410 Sports Sedan
Has thanked: 2 times
Flybridge Throttles
Post by Terra Nova »
I have a 1988 3207 Aft Cabin Carver. The Starboard throttle on my flybridge keeps slipping so I have to continuously hold it to keep it in position. Does anybody know if there is a way to adjust the cable to increase the tension? The flybridge is connected to the lower helm but I couldn't locate a connection point on those controls.
Re: Flybridge Throttles
There should be an adjustment screw on the throttle control itself to increase or decrease the amount of effort required to move it. You want a happy medium between tight enough so it doesn't spring back on you and loose enough that it can still be easily moved.
Terra Nova
Perfect! Do you know where that screw would be? I still can't find it. Would it be on the lower helm or on the flybridge helm where the issue is?
Chris86
Vessel Info: 1986 ACMY 4207, Twin 454, with previous owner's self righteous modifications.
Has thanked: 5 times
Post by Chris86 »
It should be on the sides of the throttle and shifter bodies around the arch of the lever housing.
Terra Nova
Thanks - I will take a peek in the spring. Winter is coming up here in Canada
